Rods don't fit, advice please
  • Jaswan
    • Apr 2011
    • 771
    I haven't but I will
      Get on the phone and talk to a human being, much better than emails.
      • Bowie69
        • Nov 2013
        • 2675
        Have you checked them on the crank, i.e. are they the right size?
        • Jaswan
          • Apr 2011
          • 771
          I didn't, but all vr6 are the same main bearing size.
          And you saying incase they are totally the wrong rod?
          The wrist pin fits fine and (by eye) it looks right against the oem rod
          Jase
          • FCP-ENGINEERING
            • Feb 2011
            • 173
            • Country: Lithuania
            #20
            We have rods VR6 with 5/16 arp bolts and width is less when 80mm. Fits directly to block.
            Audi S4 2.6 20V STROKER kkk26/27
            • Jaswan
              • Apr 2011
              • 771
              #21
              These are also 5/16 bolts
              • Bowie69
                • Nov 2013
                • 2675
                Yes exactly that.
                I'd check the length as well.
                • Jaswan
                  • Apr 2011
                  • 771
                  #23
                  034 want me to measure the rod bolts.
                  im hoping to get home on friday and will take another look. (the main bearings fit fine though, although i didnt try it on the crank)
                  • repo
                    • Dec 2004
                    • 893
                    Your rods are for r32, not 2.8. 3.2 has bigger bore.
                    I had same issue from a German supplier, and they would have required a hefty 3mm overbore to fit in.
                    I made a complaint, and they suggested me to sell them in ebay and buy a new set from someone who cares.
