S6 to RS2 spec
    Originally posted by prj
    It won't.
    So when HM6-S6 is at the side of the road with his RS2'd UrS6 with a split intercooler or cross-over pipe or Michelin Man hose, you will be there to drive him to his destination? Good for you.
    • andy10v
      • 5996
      Originally posted by UrS4boy
      Probably. The UrS6 cross over tube is also plastic and will split under the higher boosts that an RS2 turbo is capable of.
      Do the URS plastic ones split? The later ABY and ADU cars have plastic boost pipe over the cam cover v the earlier metal ones.
      I know the plastic intercooler ends are known to dislike high boost.
      Sold ABY-stock
        Yes it's the intercooler end caps I've heard of leaking.
        • A1QSHIP
          • Aug 2004
          • 975
          The plastic end caps come loose where they are joined to the aluminum core. I have heard of people strapping them with heavy duty zip ties. Best to fit an UrS4 all alloy one & metal cross over pipe if you do not want to go front mount.
          "Nulla tenaci invia est via"
