Searching for unicorns: 049133245 Banjo bolt with threaded head.
    I don't know what exactly it looks like. I was hoping to find a photo but I couldn't. If it is what I hope it is, it could be used to a) hold the UrS4 fuel feed line to the fuel rail and b) provide a point to insert a fitting for either a mechanical fuel pressure gauge *OR* a pressure transducer for an electronic fuel pressure gauge.
    Also used on mid-1980's VWs (KE Jetronic?)
    On the Audi side:
    On the VW side:
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    hi dave,looking for something like this?
    you can also use a dubble banjobolt like the picture i send to you from my car
    TWINCHARGED power,zero lag
    AEM W/M injection
      I'm looking for something like this, need some sort of T fitting for the ABY fuel rail though I think
      Here's an M14 double banjo bolt.. http://www.ebay.co.uk/itm/DOUBLE-BAN...item487458e3ae
        I would just drill the head to the banjo bolt and weld a hose fitting to it
        • ralleyquattro
          • Oct 2007
          • 536
          • Home: Poland Current: Canada
          They also came on Urquattros.. I should have one or two if you need it Dave.
          www.quattro.ca
          B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
          B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
            Martin: For starters, could you check the threads (the male and female) and maybe post a photo? It would be nice to know if the unicorn is really what I seek.
            • StickyWickett
              • Apr 2014
              • 89
              This came up on Google images.
              EDIT: Scratch that, just worked out the diagram and we have no such parts
              Jake
              1995 Audi S2 Avant
                Thanks Nick. That bolt looks like what I am seeking. The question is whether the threads are correct for an Audi application (I have a Russell banjo bolt with NPT female threads on the top but the male threads are wrong).
                You posted the double banjo bolt photo before. That is an option too. Just not one I am pursuing at the moment ("Plan B")
                This is the bolt you pointed me to. No details on the male thread:
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  I did a lot of searching on this a while back and gave up in the end. I could not find one with the correct metric thread and npt thread.
                  I ended drilling a hole ind the banjo bolt and welding on a boss with npt thread for the fuel pressure sensor.
                  http://www.autometer.com/fuel-press.html - But I'm pretty sure it is the wrong metric thread.
                  Sleeper S2 Avant +450
                  A6 Avant 2.7t Stage 3
                  Audi S2 Coupe RS2'ed
                    Dave, you're not going to believe this but....
                    This was in a plastic bag of bits that were left over from the rebuild of my ur, back in the late 80s, I don't think I've looked at it since then! The car had an engine bay fire and needed a new fuel metering head so I ended up with some spares..
                    I have a few of the 8mm banjo bolts and the one 8mm to 10mm male to male
                    The larger thread is 12mm x 1.5 and the small one is 8mm x 1mm
                      Confirmed Unicorn Siting.
                      Thanks for posting that up. At least I know that exists. The 12 x 1.5 is perfect but I *think* my pressure transducer is M10 x 1.
                      Close.
                        Close.
                        10 to 8mm adapter shouldn't be too hard to find.
                          Finally found the DEFI fuel pressure gauge pressure transducer/sender. It's NOT M10 x 1, it's 1/8" NPT (tapered pipe thread). So now I need to seek a new unicorn. M12 x 1.5 male and 1/8" NPT female threads.
                          • gnutz2
                            • Aug 2006
                            • 928
                            Like mentioned before, just tap a banjo 1/8 ntp.
                            The ONLY S2 Golf!
                            http://www.s2forum.com/forum/showthread.php?t=19402
                            10.42@138mph
                            https://m.youtube.com/watch?v=0wnkkOfFpXg
                              The head of the standard banjo bolt is not thick enough to allow tapping *AND* installation of the fuel pressure gauge/transducer without the gauge/transducer protruding into the banjo bolt and restricting flow into the fuel rail.
                              This is why they do this:
