Cooling "problem"
    • 4754
    It should open up at 87 degrees.
    • hunker7
      • Mar 2014
      • 3487
      It should. I guess it wasn't hot enough
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
        Not sure if the thermostat is sensitive to this / or if it is possible to put it in the wrong way around ? New rubber seal ? Always a good idea, seal on which side of the thermostat?, but very unlikely to be related to your issue, unless the seal was left out.
        But might as well fit it exactly as Audi intended.
        Look up Dave's live links to verify which sensor, MFTS or the one at the back of the head, gives a signal to the dash's temperature gauge.
        Look up how you trigger the dash gauge's wire in the engine bay to give a signal to the gauge, so that you can see that the gauge works.
        Did you read other threads on the correct and the practical ways of bleeding the system ? My recollection is that it is not always straightforward to get it right.
        Others need to chime in here.
        Post up the cure in due course.
        • hunker7
          • Mar 2014
          • 3487
          Ch.51 on Climate control panel shows 92C gauge shows 70C
          '93 Audi UrS4 Avant
          • hunker7
            • Mar 2014
            • 3487
            #20
            I've given up for today. Temperature climbs to 95C and just sits there, and thermostat isn't opening. I will leave it for tonight and see if air has escaped during the night. If not, I'll just drive it and wait for it to open.
            '93 Audi UrS4 Avant
            • Fat Audi 80
              • 10547
              Double check you have bleed the system correctly. I had similar symptoms which were air in the system...
              HTH
              The Perfectionist
              • hunker7
                • Mar 2014
                • 3487
                #22
                What is the "procedure" to bleed the system?
                '93 Audi UrS4 Avant
                  I normally squash the top hose to get the bubbles out, fill and repeat, theres a bleed screw on top of the rad, one on the hose to the heater matrix. Let the car idle till the fan cuts in which can take quite a long time in this weather, allow to cool and check the level again. The thermostat has to be fitted with the small hole at the top IIRC.
                  The MFTS feeds the gauge, cold air blowing onto it can mean a low reading, if the rubber boot is not fitted for example, or the rad ducting removed.
                  The gauge needs a regulated supply, the regulator for this is on the back of the clocks, looks like a flat power transistor fitted with a bolt. Undo the bolt, clean the legs and the bolt to be sure the contacts are good, plug it back in and bolt it down. If it is a poor contact on the reg. the fuel gauge will red low too.
                  • RoadKill
                    • Dec 2004
                    • 567
                    you bleed it when its not running open bleed screws when the coolant comes out do them up job done , you should never do it with the cap off. the coolant is under pressure to lift the boiling point
                    service tec @ East Kent Audi
                    S2 ABY
                    B8.5 A4
                    • hunker7
                      • Mar 2014
                      • 3487
                      #25
                      I fitted the new thermostat same way the old one came out (which was still oem unit). Problem I am getting here is I don't have bleed screw on top of the rad or on the hose that goes to matrix heater?
                      I might be looking in the wrong place, but I can't see a bleed screw.
                      Also, nothing has changed over night. So I am back to square one.
                      '93 Audi UrS4 Avant
                      • hunker7
                        • Mar 2014
                        • 3487
                        #26
                        Also, why isn't it overheating if thermostat is not opening?
                        '93 Audi UrS4 Avant
                        • RoadKill
                          • Dec 2004
                          • 567
                          to see the bleed screw hose that goes to matrix heater your need to take of the plastic cover off that's at the back of your engine bay and go's up to the window
                          S2 ABY
                          B8.5 A4
                          • RoadKill
                            • Dec 2004
                            • 567
                            here we go http://forums.quattroworld.com/a6100/msgs/339.phtml
                            S2 ABY
                            B8.5 A4
                            • hunker7
                              • Mar 2014
                              • 3487
                              #29
                              I looked at that, and I don't have one
                              '93 Audi UrS4 Avant
                              • Majorcina
                                • Jun 2013
                                • 1334
                                • Country: Montenegro
                                #30
                                Probably was broken,and now there is just a hose(that's what i found on my car)
