Cooling "problem"
    #46
    Originally posted by hunker7
    Burns your hands hot.
    That's good to know, as I need to investigate mind as it is useless at present, but ironically too cold to strip it on the drive these nights.
    At least I know it has the potential to be really good once I fix it. :roll eyes:
      Pull the bottom hose off again and see if you've got the inside layer of rubber turned over and blocking the pipe.
      • hunker7
        • Mar 2014
        • 3487
        #48
        Lower rad hose is good. When I turn heaters off, temp drops from right down to about 80C. As it's not overheating, I assume it's not getting upto temperature, what I can do is, drive as it is, on Friday I am going for a longer drive and keep an eye on the temperature and have water with me.
        '93 Audi UrS4 Avant
        '15 Audi A7 quattro 3.0 TDI
        • Monkeymagic
          • Mar 2012
          • 3419
          Have you actually lleft it to idle until the fans kick in? I doubt you actually have a fault
          • hunker7
            • Mar 2014
            • 3487
            #50
            I don't have a fan. I have a viscous one running off drive belt.
            I remember I had problems with bleeding the V6 system, but that was pretty easy, drove it hard for a bit and sorted.
            '93 Audi UrS4 Avant
            • Monkeymagic
              • Mar 2012
              • 3419
              So there's no electric cooling fan at all? Does the bottom hose even get warm?
              • hunker7
                • Mar 2014
                • 3487
                #52
                No electric fan for me no. It gets a bit warm.
                '93 Audi UrS4 Avant
                • RoadKill
                  • Dec 2004
                  • 567
                  no air con ?
                  service tec @ East Kent Audi
                  S2 ABY
                  B8.5 A4
                  • hunker7
                    • Mar 2014
                    • 3487
                    #54
                    Do have aircon.
                    '93 Audi UrS4 Avant
                    • hunker7
                      • Mar 2014
                      • 3487
                      #55
                      I have 140 mile round trip tomorrow, can I drive the car or it's possible to damage the engine? Worse that can happen is thermostat is going to open, and I'll be bringing water with me if that happens?
                      '93 Audi UrS4 Avant
                        How did it go?
                        • 220bhp
                          • 2578
                          • Home: United Kingdom
                          #57
                          If you can turn the fan with engine turned of,you have an electric fan.
                          • mullder
                            • Aug 2014
                            • 49
                            When you changed the thermostat all the coolant would have drained from the block. If the bottom hose is not getting hot and you know you have a good working thermostat it would suggest that there is no coolant behind the thermostat to open it. take the top hose of the rad and "fill" the block put coolant in until it runs out of the top hose then reattach it to the rad and run the car. (You may have to do this twice) This would also explain why it has not taken as much coolant as you say it should. Always found this works.
                            • hunker7
                              • Mar 2014
                              • 3487
                              #59
                              Originally posted by newsh
                              How did it go?
                              Got there and back ok. Didn't overheat, but thermostat didn't open either (I assume) as level didn't drop in the expansion tank. Did have to top it up a tiny bit but nothing major. At least now I as getting some pressure in the system, so I'll check in the morning see if has dropped again.
                              There is coolant in the block. If I take off the top hose coolant comes out straight, and when I was removing thermostat second time coolant was present. And it wouldn't run for long if there wouldn't be any coolant in the block. So dunno what's going on.
                              '93 Audi UrS4 Avant
                              • igor136
                                • Jun 2014
                                • 363
                                • Country: Croatia
                                #60
                                Drive the car without a thermostat. Then return thermostat. Check the plug. The system must be at least 1 bar pressure. Check Visco with a newspaper.
                                1-2-4-5-3
