Hi guys,
I have a slow coolant leak in my S2 Coupe ABY. I've just been topping it up every month or so as I can't find anything obvious... There's no sign of any crystalisation at any radiator inlet/outlet points and all O-rings seem tight enough and I can't find any splits in the hosing.
I've left the car idling as to get the main rad to kick in and wiggled all the hoses but no obvious leaks.
Any advice on this would be much appreciated.
Note: The aux radiator was replaced (with a new unit) about 6 months ago so I know it's improbable that this is at fault. I also have no over-heating issues and temperature remains well below 90degC unless idling.
