Hi guys,
I have a slow coolant leak in my S2 Coupe ABY. I've just been topping it up every month or so as I can't find anything obvious... There's no sign of any crystalisation at any radiator inlet/outlet points and all O-rings seem tight enough and I can't find any splits in the hosing.
I've left the car idling as to get the main rad to kick in and wiggled all the hoses but no obvious leaks.
Any advice on this would be much appreciated.
Note: The aux radiator was replaced (with a new unit) about 6 months ago so I know it's improbable that this is at fault. I also have no over-heating issues and temperature remains well below 90degC unless idling.
then you should have a look at and book mark the link below to the live version of my engine bay device map. Click on the device label for which you are looking, i.e. Auxiliary after-run coolant pump on the right side of the diagram in this case: (You will need the diagram in the future to answer more questions)
