had a friends URS4 come in the shop recently with a no run condition. first i assumed it was either one of the crank sensors or the cam sensor. i started with the cam sensor and to my amazement when i unplugged the cam sensor the connector on the sensor fell apart so i assumed that was my problem. i soldered in a new plug off of a junk cam sensor and the car fired right up. anyhow a day later the car is back again with a no run and my buddy said the tach was jumping around so than i pointed the finger at the G28, the RPM sensor. i took the pair that was almost brand new off of my AAN swapped 4000 and installled them on the car and it fired right up again. this time i just let it sit and idle for around 10 minutes where it than just shut off. i never shut the key off or anything and i hooked my laptop to it and proceeded to scan the ECU with vag com.
the fault i found that i cannot find any information on at all. also the fault was displayed 3 times which i found really strange.
i tried googleing it and there is absolutely nothing about this fault at all. have any of you seen this before and what was the cause of this odd fault?
Code:
07687-unkonwn error code- open short to plus
