Those who run LPG converted 2.2's
  • diesel des
    • 3896
    #361
    Think I cut the wires or pulled the pins from the plug and pushed then through a grommet then put it together again.
    • hunker7
      • Mar 2014
      • 3487
      #362
      Oh I didn't think of that, thanks
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • hunker7
        • Mar 2014
        • 3487
        #363
        What will I have to do once it's connected and working? Asking these questions now, because I will only have couple of days to mess about with it.
        '93 Audi UrS4 Avant
        • diesel des
          • 3896
          #364
          You can see what the afr ratio is on petrol and gas. In boost you want it leaner on gas than petrol.
          • hunker7
            • Mar 2014
            • 3487
            #365
            So I should be looking at 14.7 at idle, when under boost not lower than 12, according to PRJ for stock map, but mine is stage 1?
            Idle should be at 14.7 for lpg too? By how much leaner we are talking?
            '93 Audi UrS4 Avant
            • diesel des
              • 3896
              #366
              On gas on boost set the afr to 12.5 to 13.2:1
              • hunker7
                • Mar 2014
                • 3487
                #367
                How do I set it? Just using modelling tab, or is there something that will make my life easier?
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #368
                  Modeling tab. Look at afr and also the point on the graph and adjust to suit.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #369
                    So every time I'll adjust points, and write it afr will change, no need to reset ECU or anything?
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #370
                      Yep when on boost the Motronic goes open loop and doesn't know what the afr ratio is so when you adjust it in the gas ecu that's all you need to do.
                      • hunker7
                        • Mar 2014
                        • 3487
                        #371
                        Sound Is LPG running leaner because of increased EGT?
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #372
                          Petrol cools with rich mixture. Lpg gets hotter with rich mixture as it's not a liquid. So don't run it as rich. I measured egt 30 deg c cooler on Lpg doing this.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #373
                            Makes sense thanks Des Once I have it set up, I will log it as well on a quick drive to see if it runs properly.
                            '93 Audi UrS4 Avant
                            • hunker7
                              • Mar 2014
                              • 3487
                              #374
                              Planning on fitting wide band this weekend. Yellow wire connects as "narrowband" output for Motronic if I'm correct?
                              What is SERIAL IN & OUT for?
                              Where best to connect white wire?
                              '93 Audi UrS4 Avant
                              • diesel des
                                • 3896
                                #375
                                Yep your wires sound ok. White needs connected to a light circuit to dim the display.
