Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #391
    I've done some driving and she runs beautifully, but I noticed check engine light comes on at certain speeds?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • diesel des
      • 3896
      #392
      The gas times must still be not be close enough to the petrol times. At some points.
      • hunker7
        • Mar 2014
        • 3487
        #393
        I guess only way to adjust is with laptop connected and being on the move?
        '93 Audi UrS4 Avant
        • diesel des
          • 3896
          #394
          That's the way to do it best
          • hunker7
            • Mar 2014
            • 3487
            #395
            So I check petrol ms and petrol ms on gas and adjust? I will get my dad to drive it then as that is the only way I can be in charge of the laptop But apart from little things like that it runs perfectly.
            I've also ordered a KME PW2 level sensor so I can get level indicator working finally.
            '93 Audi UrS4 Avant
            • diesel des
              • 3896
              #396
              Yes monitor Motronic times on petrol and quickly switch to gas and it should be the same. Get you dad to hold a very steady throttle. And repeat at different loads. Only at high loads when Motronic is open loop should the Lpg be leaner.
              • hunker7
                • Mar 2014
                • 3487
                #397
                The window at which CEL comes on is small, I touch throttle slightly or drop speed slightly it goes off.
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #398
                  That is the area you need to concentrate in. The error is for mixture adaption right?
                  • hunker7
                    • Mar 2014
                    • 3487
                    #399
                    Well just go and drive, and adjust whrn it comes on. I assume so. Because it goes away all the time. I always get it at 75mph in 6th gear for instance.
                    '93 Audi UrS4 Avant
                    • hunker7
                      • Mar 2014
                      • 3487
                      #400
                      Had to drive on petrol and noticed it was running rich AFR 12 on idle. I assume it can't be caused by lpg ?
                      '93 Audi UrS4 Avant
                      • diesel des
                        • 3896
                        #401
                        No it's a Motronic issue. Maf?
                        • hunker7
                          • Mar 2014
                          • 3487
                          #402
                          New reconditioned unit fitted not so long ago.
                          '93 Audi UrS4 Avant
                          • prj
                            • Mar 2010
                            • 6308
                            It can if you let the fuel trims go haywire on lpg.
                            • diesel des
                              • 3896
                              #404
                              Is there a way of seeing the Motronic fuel trims Dmitry? Could help to set up the Lpg system.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #405
                                Finally got USB to serial adapter, is there any specific settings I should use for wide band?
                                '93 Audi UrS4 Avant
