I've done some driving and she runs beautifully, but I noticed check engine light comes on at certain speeds?
Those who run LPG converted 2.2's
So I check petrol ms and petrol ms on gas and adjust? I will get my dad to drive it then as that is the only way I can be in charge of the laptop
But apart from little things like that it runs perfectly.
I've also ordered a KME PW2 level sensor so I can get level indicator working finally.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
Yes monitor Motronic times on petrol and quickly switch to gas and it should be the same. Get you dad to hold a very steady throttle. And repeat at different loads. Only at high loads when Motronic is open loop should the Lpg be leaner.
Sent from my LG-H955 using TapatalkComment
That is the area you need to concentrate in. The error is for mixture adaption right?
Well just go and drive, and adjust whrn it comes on. I assume so. Because it goes away all the time. I always get it at 75mph in 6th gear for instance.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Is there a way of seeing the Motronic fuel trims Dmitry? Could help to set up the Lpg system.
