Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #511
    Something is definately not good with motronic as it runs 0.75 at points and can feel it loosing power, before it was about 0.8. What could cause rich running?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • diesel des
      • 3896
      #512
      A boost leak or the maf sensor. I had lots of maf issues which would cause a varying afr.
      • hunker7
        • Mar 2014
        • 3487
        #513
        Done full boost test and vacuum hose buried deep within was leaking, same vacuum hose was connected to the reducer. Returned the points back to where they were and she runs again. Runs at 0.7something at the moment, but I'll adjust bring it down to get it down to 0.9, don't fancy melting **** down.
        I think it's time to make some kind of vacuum connector manifold, too many T-pieces now.
        '93 Audi UrS4 Avant
        • hunker7
          • Mar 2014
          • 3487
          #514
          All sorted now, might need a little adjustment here and there but this is as close as I could get it with multi and adjusting last point a little.
          '93 Audi UrS4 Avant
          • diesel des
            • 3896
            #515
            Cool glad it was something simple.
            • hunker7
              • Mar 2014
              • 3487
              #516
              Feel kind of stupid now knowing it was such a simple thing, but the extra wiring from LPG system makes it hard to see things
              '93 Audi UrS4 Avant
