My aby s2 has started to smoke recently.
It smokes on idle 2-3 mins after starting up.
It also smokes on boost leaving a puff of blue smoke behind.
It's taking around 1 litre of oil every 600-700 miles.
Firstly, I did a compression test with the following result:
Cylinder 1: 11 bar
Cylinder 2: 11 bar
Cylinder 3: 10.5 bar
Cylinder 4: 11 bar
Cylinder 5: 11.5 bar
They all seem fine.
I checked both the hot side and cold side of the turbo for oil but were both dry with no oil residue.
There is also minimal play in the turbo shaft.
The turbo still boosts to 1.5 bar (it's got a prj map).
There seems to be no loss in power or acceleration that I've noticed.
My next step was to check all the hoses.
All hoses were dry including the intercooler pipes, inlet pipe etc.
I then had a look at the air filter box to turbo hose.
This was full of oil residue.
Where is the oil coming from?
Is this a pcv issue?
Any ideas what would be causing this?
Cylinder 1: 11 bar
Cylinder 2: 11 bar
Cylinder 4: 11 bar
They all seem fine.
cant wait )
