oldman went out this morning to find the car wont start been running fine with no probs but its not getting a spark from the coil. checked the timing first as this was problem last time all ok. changed crank sensor (white plug) and the coil unit with a knowen working one. anyone know where the 3b gets its signal to spark the coil?
3b no spark again
Imola B6 S4 Avant -
Describe how you checked the timing. Flywheel, inside dizzy and cams?
Does the car have an aftermarket alarm immobiliser?Comment
Can you read codes with Vagcom?
Or blink the codes with a LED?
You can also check the hall sensor signal with an LED I think..
If that was ok I'd maybe take the starter motor off and check that the timing pin is present.Comment
Sorry to highjack a bit - are 7a/3b hall sensors units the same or have the same specs as a AAN cam position sensor units (just thesensor itself) ? I fitted one (it fits) but haven't tested in the car yet. Easier to source - 15$ US at EFI express on this side of the pond.Comment
