Did I have problems with my coupe quattro a few years ago when heading for the Ring, now my 90 quattro is playing up and I have a meet/track session planned on this sunday.
Hopefully here are some K-Jet experts that could point me in the right direction.
First I will explain what has been done the past few days, this was just a general check/service. The car did not have real problems:
- new spark plugs, distributor cap and rotor
- new air filter
- ISV cleaned up because it ran like 2000 rpm on idle
- throttle body cleaned up
- K-Jet measuring flap cleaned up
- removed gunk from the PCV system hoses
- had the underside of the dash off under the steering wheel because there was quite a bit of play in the steering column
- removed the K-Jet from the top of the air filter box to check the piston in there. I did this because when the engine was warm it took a long while to start due to too much petrol I persume. Cleaned the piston up, there was some scoring on the top but nothing that can be felt by hand. Put the spring back in and the piston.
- when I removed the K-Jet from the filter box top section I did unscrew the torx bolts as well with don't actually hold the K-Jet itsself, so I put those back in. What do these torx bolts do?
All this was done at the same time and the car has not been started in between jobs.
Now the issues:
- car is very hard to start, overfuels by the looks of it
- won't idle at all, also not when up to temp
- when the throttle is released the engine dies immediately
- during driving the battery light glows but not constantly
- battery light blink during cranking over
- oil pressure alarm? beeps when the ignition is turned on
All in all the car is useless at the moment and it will be very hard to get it running by sunday
My guess for the running issues is that I have f*cked something up in the K-Jet. The piston seems to move freely enough though. I will at least try to get another K-Jet by the weekend but that will be hard.
Thanks in advance for your help
- new air filter
Now the issues:
