Hi guys been having bad boost problems i replaced maf all hoeses are fine and only thing that keeps coming up on e fault codes is camshaft position hall sensor signal shorts with power intermittent. .. can anyone share some light please im desperate now been bugging me for days -.-
Cheers guys
J
Read and ask questions, as needed.
I just asked lmao iv read everything but havent come across the problem im having ... the g40 (camshaft sensor) keeps putting my car into limp mode so i have no boost whatso ever theres signal coming from the ecu to the sensor but on the scanner it just comes up crank sensor short with power intermittent iv cleaned and put it back on but no different any clues? "/
Possibly, checking the timing is pretty easy and worth doing before you go any further. I know for certain that you can lose boost if the timing is a tooth out.
Im not loosing boost im not getting any at all just straight limp mode and a fault code of 0515 i think it was if i disconnected the maf i had 1 bar boost ... its NOT the maf as i replaced it aswell as checked all pipes i had scanner on numerous times cleared codes went for drives rescanned it same fault came up ... camshaft fault intimittent
...havent come across the problem im having ... the g40 (camshaft sensor) keeps putting my car into limp mode so i have no boost whatso ever theres signal coming from the ecu to the sensor but on the scanner it just comes up cam (edit) sensor short with power intermittent iv cleaned and put it back on but no different any clues? "
Did you miss this in the link I provided? Read the Signal Failure info: (Also see text under the figure):
* 2113 (Blink Fault Code), 00515 VAG1551/2 Fault Code Number
(G40) Hall sensor in distributor
(3B, early AAN engines) or camshaft position Hall Effect sensor later S4/S6 AAN engine).
Distributor alignment, faulty sender, Mis-located sensor & distributor, Cam timing possibly incorrect on AAN engine, Check lower Crankshaft Gear keyway
Im only getting short with power dunno if its going short to positive or short to ground ... this morning i had problems starting the car eventually started but its been giving me limp mode before now hence when the car didnt start this morning it made me think it was defo in need of another camshaft position sensor
Im only getting short with power dunno if its going short to positive or short to ground ... this morning i had problems starting the car eventually started but its been giving me limp mode before now hence when the car didnt start this morning it made me think it was defo in need of another camshaft position sensor.
You are asking the Audi Gods to Smite you with vengeance by ignoring the signs of impending doom.
But check out the wiring at the connector/plug.
I was literally just looking at that but how do i test it what volts should i be getting out of what wire. . I had multimeter out earlier i was getting 5v on positive but dunno what im looking for in the other 2 wires
