boost lag and fuel economy question
  • hunker7
    replied
    Originally posted by slim100s4
    Have you replaced the lambda sensor that's also another thing I have changed in the past.
    I had a low milage "universal" Denso lambda from my V6 which I fitted, didn't change a thing.
  • slim100s4
    replied
  • hunker7
    replied
    I reset it and drive for some time and it usually ends up at at a really low number.
  • slim100s4
    replied
    Do you reset the trip computer?
  • hunker7
    replied
    My s6 had bad mpg when I first got it sat at 18 mpg all the time. I changed fuel filter put some injector cleaner in and did the coil pack upgrade and now iam getting 23-24 around town and on a run last nite I was getting 32 mpg sitting at 60 and giving it the odd squirt overtaking.
    This is why I think something is wrong with mine. I have a new fuel filter, new filters in injectors and pump hasn't done loads of miles either, and I have TFSI coil conversion done.
    Best I can do is 15mpg and that's planning ahead and basically not driving
    Going to Leeds tomorrow so good 200 miles, I'll see what she does on a motorway.
  • slim100s4
    replied
    I was surprised what mpg I was getting myself that's why I took the photo.
  • slim100s4
    replied
  • hunker7
    replied
    Originally posted by A80Avant
    Sure you can assemble it incorrectly. Make sure the timing marks are always half tooth out. I'm sure there are images here. I have never done this myself as I'm not a mechanic but I see this issue coming up again and again
    How? Because lower pulley has a key way, and there is like a pin on it so you can fit the lower drive belt pulley.
    Also, don't understand what you mean by "Make sure the timing marks are always half tooth out."
  • A80Avant
    replied
  • hunker7
    replied
    Originally posted by Error404
    With no signal from the knock sensors the ECU will cut boost and I assume also pull timing; you will be in limp mode.
    I would say it seems more likely to be a mechanical issue since it's been evident since you put it all back together.
    I would go back over everything that has been loosened, removed or fitted and check it all
    All I had off was intake/exhaust sides and timing belt, and assembling you can't really put it back together wrong. I've been thinking and I can't think of anything that could have gone wrong.
    You checked the timing with a strobe light?
    This issue brings in mind the timing belt sprocket and the half tooth out issue. Car can be idling nice just different camshaft positions.
    I've changed lower timing belt pulley, and you can't assemble it incorrectly as far as I know
    Strobe on AAN?
    Turbo itself had tiniest of movement, hoses are not in the greatest of shapes but there are no splits.
  • A80Avant
    replied
    replied
  • hunker7
    replied
    Originally posted by 220bhp
    Two things with knock sensors. The wire degrades, and the wrong torque setting.
    The fact that there are no codes is a pain.
    It took me along time to trace this issue when I first got my car. By then I had replaced just about everything.
    Knock sensors have been torqued to 20Nm
    Could I test it by unplugging them one at the time?
  • 220bhp
    replied
  • hunker7
    replied
    11 is achievable if you try hard
    Has it been like this since you put it back together?
    I would envisage a mechanical issue or a knock sensor fault which can cause issues without throwing codes
    It has yes, as soon as I put it together I noticed the lag and fuel problem
    Where do I start with this, I don't fancy spending hundreds on parts that are working fine. I inspected knock sensors when I had them off and they seemed fine visually with no cracks etc.
