Hmmm, I guess that at 12psi that would be about right for the lower end. I'm using a VDO boost guage to read the boost level. I rate VDO but nothing is perfect. I am right in thinking that you can't read boost in measuring blocks aren't I? I couldn't find it.
I'll stick up a wanted add for a set of original S6 manual chips and put them in the modified ECU. Hopefully, the internal MAP sensor is ok as it's still there...
MG
MG
Agree with almost every word.
