All who have modified cylinder heads and have changed the valves please post here, what exhaust valves do you use? Do you still use the sodium filled stock turbo valves(3B, AAN, ABY, ADU) or if you use a 7A head, do you use the 7A valves(non sodium filled). Or do you use second hand valves, normal non filled, sodium filled, stainless, titanium..? Why did you choose the valves you use? If you use 7A or normal second hand valves, how much power do you run? Please post the brand of you valves also.
Modified head - what valves do you run? Poll!
71Stock sodium filled turbo valves60.56%437A valves (non filled)8.45%6Normal second hand valves (non filled)1.41%1Sodium filled second hand valves4.23%3Stainless valves19.72%14Titanium valves5.63%4Last edited by Thuppu; 25 October 2015, 11:39.
BMW 740iA e38 - ProjectTags: None -
99 2.8 final edition Cabriolet -
Yes, some of the 7A heads have sodium filled valves, propably in the beginning when production started Audi used them..? I belive in the end most 7A heads have normal valves, but of course it's hard to tell if someone is using 7A valves, which they are, if not weighted.
BMW 740iA e38 - ProjectComment
Thomas,
I just pulled the exhaust valves off the 7A head.
Mine got non sodium filled (part#611D).the parts#
is located on the top groove.I'm going to use this
On my AAN head.one of a few I5 from Asia.Comment
Ok, atm I'm using stock head and AAN valves. Latest power figures 624hp/737Nm, and have been revving up to 8100rpm. Just thinkin of using 7A valves in my next head, but don't know how much power they can take..? A friend of my snapped a "hollow" AAN valve and that was not pretty.Last edited by Thuppu; 25 October 2015, 12:56.
Hi Thuppu I'm not willing to take the risk with used valves.as I've btdt on my golf
But I do know that Andyp had a valve drop on his engine because of wear on a valve,and he showed me piston Which had a hole through it
I believe it was sodium filled valves he used as well.
I'm still looking for valves to pick for my head. Don't want to go too cheap. Stumbled upon some TRW valves, dunno if I can get them here though.
What about RS2 valves in AAN/ABY/3B? Do they fit? I'm getting 2 different part numbers for RS2 valves for some reason.Last edited by RichLV; 25 October 2015, 13:44.Comment
Inconel missing off poll list. A popular material for running near the ragged edge.Volcano ABY coupe
AntComment
Do you know the weights of either of them? It would be nice to check my very low mileage 7A head and see what i have.
99 2.8 final edition CabrioletComment
Im running supertec exhaust valves in inconel/super alloy and stainless inlets on my stroker road car and will run the same on my URQ build. 450bhp and over 700nm torque.Comment
