Hi, guys. I m having problems with my 3b hall inside dizzy. Twice I have broken camshaft on intake side just on the dizzy gear. So I think to place sensor on cam gear. I have read in forum that a bracket can be welded under cam gear and sensor can be positioned there. If I use an AAN cam gear what other things I have to change?
Do I have to change water pump, oil pump, belt and tensioner?
Then come back and ask questions.
Usually a threaded piece of ally is welded on the head where you can fit the hall bracket, no difference really.
If it's in right place there isn't any difference if it's welded or bolted down. Quite a lot easier to just weld it on than machine a flat spot and make holes and threads etc...
JP's style:
Sorry. Seems dodgy to me. And what happens when the actual sender portion fails and needs replacement? Seems like a lot of future "fun"
Ehh... you need to switch the lights on Dave. If the sender fails you just swap in a new sender, no difference to the OE solution. Of course the actual hall bracket is bolt on the alu piece, you can't weld steel on aluminium. (if I remember right the hall bracket is steel)
You remember wrong. The bracket is something cast (aluminum or ??). From your photo, I couldn't tell that the bracket was a separate piece. On closer inspection, I can *just* see the separate bracket.
Photo showing the factory G40 on its factory G40 bracket:
Ok, I did remember wrong, but anyway welding it wouldn't be so smart.
No proble welding the bracket ( have done it on many 7a heads ) , but there is also possibel to drill a hole and make threads and make a qucik bracket , cant find the picture of the easy solution
i made a template to get the proper location of the bracket (the sensor will bolt onto this, just like with the OEM) copying an aan head
then, i welded the bracket (was made by JP on this forum)
How often do you hit the rev limiter? How often do you check the cam cap nuts for tightness?
If I have to be honest I hit rev limiter very often (almost every time I change gear). The car is near 750 crank hp. I dont check for tightness. I tight bolts with torque wrench.
