After many hours I finally can share my twincharged project with you!
First I made some room in front
then I made 2 supports for the sc and made some adaptions on the crossmember
the sc is a 1420cc roots sc from a toyota previa with clutch
afterwards I adjusted the crankshaft pulley
the multi-v-drive is about 200 mm and comes from a american v8 engine
on the picture you see from right to left,AAN pulley-kv pulley-v8 pulley
I dismantled the compressor and cleaned everything + new oil in the sc
i made a custom boostpipe with w/M injector in place,spray it with black paint and mount it on the sc
time to place the sc on the engine for good
for the bypass valve i choose for an electric throttlebody(70mm) from a vw 2.3 vr5 engine because you can open this on 2 ways,electric and by a cable
made some adaptions on it and mounted on the boostpipe,now it can open electric and with a custom made waste gate valve from a diesel turbo
then i made the second boostpipe
made a total new frontplate on the crossmember
because of the small room now on the left it was Necessary to place a new smaller oil cooler.
time to place the front back together
then it was time to adjust the steering pump
i choose for an electric pump from a opel astra
naturally i designed a custom support again
When it was finished I started to place the W/M injection from AEM
afterwards I finally can go test drive on the road and adjust the mapping along with the W/M injection.
the clutch from the sc is activated between 900-4000 rpm,45%-100% throttlebody
after 4000 rpm the turbo takes over
Today I have been on the dyno with some good and bad results
good:the car pulls very quickly
bad: in some way i've lost some 73hp on the end
in the past i made with turbo 520 hp and 636 nm torque and now twincharged 447 hp and 566 nm torque with the same dyno
I do not know how it happens, all the values are good and I come smoothly on my turbo pressure (2bar)
maybe restriction from the hoses and custom boostpipes?
this I'm going to repair in the future
and now some pictures,enjoy
,has this once while mapping
