This is a great thread - thanks for sharing!
my twincharged project
Even how I try to think about it, I can't figure why it will loose so much power... In theory it shouldn't.
Did you try to go with more max boost?
BMW 740iA e38 - ProjectComment
thanks
now just need to repair the horsepower loss in the future
on 14 november(belgian vw-audi club day) i go to drive on track
i hope that my drivetrain will hold the torque power
TWINCHARGED power,zero lag
AEM W/M injectionComment
we have tried with 2.2 bar boost( 0.2 boost more) and gain only 8hp,to low so the problem is not boost,i think it's a flow problem,not boost pressureaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
yes andy,when clutch is activated,the throttlebody is closed,powerd by a spring(no electric),on 4000 rpm the clutch will deactivated and throttlebody goes open but already than is the throttlebody half open by waste gate.this is necessary for controlling the boost from sc and turbo together
you can see this very well in the movie,first move the waste gate,then it goes electric
further open(see the little metal on the top moving)audi coupe quattro b2 2.2 20vt project (573hp-626nm)
my girlfriend think otherwise sometimes
i only want my 520 hp back,that's more than enough
Really interesting Nick, really like it - I didn't realise you had actually completed the fabrication...!
Sorry I don't have any suggestions for the lost power, but I imagine it feels amazing on the street, with so much torque low down...
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
thanks chris!
yeah,for the lost power i have allready an idee to solve it
i gonna change the boostpipe from ic to sc and bypass valve with a bigger diameter(63mm to 70mm) and go to place a second valve in the sc inlet that closes afther 4000 rpm so turboboost can not in to the supercharger
but all this is for the future
If boost is the same as before and IAT is the same it should make the same Power. If there are restrictions in the system the turbo must be pushed harder to give the same boost so could be a reason for power loss.
What about the cam timing? I looks like you made a new pulley. Are you sure timing is correct? Checked that mark on pulley really is TDC?Comment
0-200km/h 9sec
