my twincharged project
  • ColonialNomad
    • Feb 2015
    • 392
    • Home: United Kingdom Current: China
    This is a great thread - thanks for sharing!
    • andy10v
      • 5996
      That is really cool! You have really filled in the bottom end on the graph, so much low end torque.
      Sold ABY-stock
      • Thuppu
        • 4115
        Even how I try to think about it, I can't figure why it will loose so much power... In theory it shouldn't. Did you try to go with more max boost?
        • andy10v
          • 5996
          Does the electric throttle stay 100% open at peak power?
          Sold ABY-stock
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #20
            thanks
            now just need to repair the horsepower loss in the future
            on 14 november(belgian vw-audi club day) i go to drive on track
            i hope that my drivetrain will hold the torque power
            TWINCHARGED power,zero lag
            AEM W/M injection
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              #21
              we have tried with 2.2 bar boost( 0.2 boost more) and gain only 8hp,to low so the problem is not boost,i think it's a flow problem,not boost pressure
              AEM W/M injection
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #22
                yes andy,when clutch is activated,the throttlebody is closed,powerd by a spring(no electric),on 4000 rpm the clutch will deactivated and throttlebody goes open but already than is the throttlebody half open by waste gate.this is necessary for controlling the boost from sc and turbo together
                you can see this very well in the movie,first move the waste gate,then it goes electric
                further open(see the little metal on the top moving)
                AEM W/M injection
                • SteveH
                  • 4460
                  You must have some serious spare time
                  Nice project, hope you iron out the loss of horses.
                  91 Modded 3B
                  14 A6 Avant Black Edition
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #24
                    my girlfriend think otherwise sometimes
                    AEM W/M injection
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #25
                      I bet
                      Great effort eh?
                      Keep pushing it until you break something, and start again
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #26
                        i only want my 520 hp back,that's more than enough
                        AEM W/M injection
                        • LHD_Kid
                          • May 2006
                          • 3696
                          #27
                          Really interesting Nick, really like it - I didn't realise you had actually completed the fabrication...!
                          Sorry I don't have any suggestions for the lost power, but I imagine it feels amazing on the street, with so much torque low down...
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            #28
                            thanks chris!
                            yeah,for the lost power i have allready an idee to solve it
                            i gonna change the boostpipe from ic to sc and bypass valve with a bigger diameter(63mm to 70mm) and go to place a second valve in the sc inlet that closes afther 4000 rpm so turboboost can not in to the supercharger
                            but all this is for the future
                            AEM W/M injection
                            • Audi_CQ
                              • 940
                              • Country: Norway
                              #29
                              If boost is the same as before and IAT is the same it should make the same Power. If there are restrictions in the system the turbo must be pushed harder to give the same boost so could be a reason for power loss.
                              What about the cam timing? I looks like you made a new pulley. Are you sure timing is correct? Checked that mark on pulley really is TDC?
                              • V6quattro
                                • Sep 2008
                                • 949
                                Very nice Nick!
