my twincharged project
    Originally posted by quattro-nick
    i have changed the AAN cams for 7A cams
    the inlet cam was not a straight fit,the dizzy gear was different.i have a older AAN engine with a diizzy (tunacan) for camshaft sensor
    with some heating i switched the gear on the cam
    left intake cam 7A-right AAN intake cam
    Good job. So left = 7A, right = AAN (just to confirm):
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      #167
      yes dave,the gear from my AAN is a 2 piece gear with a spring in it between the 2 gears .the rear part can move a little
      the 7a intake cam have a little gear with less teeth
      TWINCHARGED power,zero lag
      AEM W/M injection
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        #168
        tuesday dynoday!
        all thumbs up for me guys!
        hope to get around 550hp
        AEM W/M injection
        • Majorcina
          • Jun 2013
          • 1334
          • Country: Montenegro
          #169
          Looking forward for results 😃
          Poslato sa G7-L01 uz pomoć Tapatoka
          • LHD_Kid
            • May 2006
            • 3695
            #170
            Me too...!!
            • oldestof11
              • May 2016
              • 5
              Coming into this late so bear with me. I'm coming from the diesel truck world with a few twin charged trucks that I've watched built.
              Why is the turbo feeding the SC? The SC will be a restriction at high RPM/boost. There's also an issue with rotor flex when feeding a super with boost.
              What I've seen done is a super feeding a rather larger turbo. The idea is super for low RPM and turbo for high without the restriction of compound turbo charging. So the SC, when the turbo can neutralize the the incoming air so it's atmospheric pressure, starts freewheeling. Then if the turbo demands yet even more, the bypass valve on the intake of the super opens to start feeding the turbo directly.
              So it goes
              Filter
              Piping
              Diverter valve
              Super
              Turbo intake
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #172
                a made this setup because i had no room to make it otherwise like you have said
                the sc is not a restriction on higher rpm because after 4800 rpm the sc cut out and the bypass valve goes open so boost flows from ic straight to the intake like a normal setup
                AEM W/M injection
                • quattro-nick
                  • Sep 2012
                  • 1746
                  • Country: Belgium
                  #173
                  today was my dynoday
                  everything went well and no broken pieces
                  this was the first pull,programmed by me on the road
                  on 6300 rpm there was a powerdrop caused by a to rich fuel ratio,lambda 0.65
                  AEM W/M injection
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #174
                    en this is the final pull after about 2 hours
                    very happy with the results,562 hp and 600 nm torque
                    AEM W/M injection
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      #175
                      small vid from the last pull
                      AEM W/M injection
                      • Thuppu
                        • 4115
                        Nice! Good result.
                        • Majorcina
                          • Jun 2013
                          • 1334
                          #177
                          Nice How the car feels now?
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            #178
                            very fast!
                            AEM W/M injection
                            • Majorcina
                              • Jun 2013
                              • 1334
                              #179
                              Oh put some videos when you get time 😃
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #180
                                will do
                                AEM W/M injection
