my twincharged project
  • diesel des
    • 3896
    #181
    Could your rpm be increased? Your power is still climbing at high rpm so why stop?
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      #182
      yeah des,i noticed it too,max rpm now 7200
      but i use still hydraulic lifters and the crank with flywheel is not balanced so how for can you go with this?
      TWINCHARGED power,zero lag
      AEM W/M injection
      • V6quattro
        • Sep 2008
        • 949
        I'm running 8000rpm on hydro lifters but my crank is balanced.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          #184
          maybe 7500 doable?
          AEM W/M injection
          • diesel des
            • 3896
            #185
            Yea no problem. I was running up to 7800 on a stock bottom end engine no problem. For short blasts it ok but don't spend all day on the limiter.
            • vti2
              • Jul 2010
              • 281
              • Home: Portugal Current: Germany
              #186
              Your Problem ist that you Need a Second intercooler for The supercharger, you Are pushing hot Air to The Engine so no power.
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #187
                i dont have hot air problems!
                i use aem W/M injection with one injector before throttlebody and this is active from 0.5-2.0 bar boost.
                intake air temp on full load is max 30°c
                AEM W/M injection
                • jsws3
                  • Apr 2012
                  • 1174
                  How much above ambient is your intake temps mate when normal road driving ?
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #189
                    i dont know
                    on normal driving the supercharger is disconnected
                    i will take a look on the next test driving with vems
                    how is your intake temp?
                    AEM W/M injection
                    • jsws3
                      • Apr 2012
                      • 1174
                      i dont know
                      Around 9-12 above ambient normal 60mph B road driving
                      15-19 spanking it hard down the B roads
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #191
                        thats low
                        only with ic?
                        AEM W/M injection
                        • jsws3
                          • Apr 2012
                          • 1174
                          Yes mate only one however the core cost me £900
                          • afterburner
                            • Mar 2012
                            • 246
                            • Country: Bulgaria
                            #193
                            Have you tried spraying before the supercharger? Any thoughts on that? Should (based on reading stuff online, so no experience) improve the supercharger's efficiency...
                            • vti2
                              • Jul 2010
                              • 281
                              #194
                              a .82 turbine housing is also too small, getting too much backpressure.
                              • Thuppu
                                • 4115
                                What is the problem?
