fuel injector recommendations
  • orignalS60
    • Mar 2015
    • 792
    • Home: Croatia Current: United States
    I bought these spacers:
    http://m.ebay.com/itm/Fuel-Injector-...ATCHING_ACTIVE
    and these harness adapters:
    http://m.ebay.com/itm/6-USCAR-EV6-EV...ATCHING_ACTIVE
    Do they look alright?
    • Thuppu
      • 4115
      They look ok.
      • Audi_CQ
        • 940
        • Country: Norway
        Originally posted by V6quattro
        Around 95% yes.
        I've got about the same power and are running 10x630cc (@3bar) with 4 bar fuel pressure so should be about the same as your setup, but I only needed 12,5ms at 7000 to get 12 in AFR. About 20% less then your injector time. A large difference for something that should be about the same if you look only on injector CC.......
        • V6quattro
          • Sep 2008
          • 949
          How would you think thats posible? Maybe its from you running 10 injectors and i 5?
          • rst
            • May 2006
            • 102
            I have 5x1200cc@3bar EV14 injectors and using them at 4bar fuel pressure (~1350cc).
            I am running E91 (10 part ethanol and 1 part gasoline) and lambda target 0.75.
            Injector duty ~90% and pulse width 19ms.
            Audi UrS4 609hp/846Nm @ wheels
            10.911@210, 1km 268km/h, 1mile 295km/h
            FATS 2,30 sec
            • V6quattro
              • Sep 2008
              • 949
              I am running E91 (10 part ethanol and 1 part gasoline).
              Hy ware do you get your e100?
              • michaels2s
                • Nov 2012
                • 87
                Hey Roy
                Some Guys in Germany order here...maybe they supply Holland also.
                I think so...
                [__]=oooo=[__]
                • rst
                  • May 2006
                  • 102
                  Local chemical liquid seller offers 99.9% pure ethanol (~1€/L), something is mixed in so it would be not drinkable.
                  You can search local chemical liquid seller who offers denaturated ethanol.
                  E85 mix
                  FATS 2,30 sec
                  • V6quattro
                    • Sep 2008
                    • 949
                    Thanks guys Its starting to get more difficult to get E85 today
                    • diesel des
                      • 3896
                      #25
                      These are the same size as I have got for my urq project. What power are you running? The turbo I have will do 600 to 650 bhp on petrol and 700 ish on e85.
                      • rst
                        • May 2006
                        • 102
                        DYNO sheet. Power is from wheels.
                        FATS 2,30 sec
                        • Audi_CQ
                          • 940
                          • Country: Norway
                          #27
                          Not sure
                          10x630 should be about the same as 5x1200. Are you sure that your fuel pressure is right when at max power? If it is dropping(not following boost pressure 100%) you would have to compansate with longer opening times.
                          Or maybe the 1200 injectors gives a bit less then quoted and the 630 a bit more so the difference is >10% and not 5?
                          A combination of the above?
                          • orignalS60
                            • Mar 2015
                            • 792
                            #28
                            For anyone interested here's a link
                            to inexpesive 2,200cc bosch injectors:
                            http://m.ebay.com/itm/BOSCH-Gas-Petr...ATCHING_ACTIVE
                            Seller is located in Europe.
