RS2+ spec
  • quattrostyle
    • Oct 2006
    • 6229
    Regarding the weight of the car, i'm curious to know what it actually weighs with a 20VT in it. My 90 quattro weighs 1210 kg. with only a couple litres of fuel in it, stock 2.2 engine but with ABS and catalyst.
    • Colesy
      • Feb 2009
      • 2980
      Originally posted by K Simmonds
      As above a good remap/chip set using the stock hardware will get you to 280BHP and be pretty dam quick in a 1200kg car. My S2 is a little over 1300kg's running full RS2 spec, so 350BHP ish and it's more than fast enough for day to day road use.
      I am in a similar position, running full RS2 spec and the car is very fast, probably fast enough I just keep getting the question pop into my head, "I wonder how fast 450 would be?"...
      • Rikki Kitto
        • Feb 2010
        • 6276
        Regarding headwork JP is your man JNL racing
          Not sure about the 10v, but the ABY set-up doesn't weight much more than 7A for exampe - the only additional weight really is turbo, intercooler and oil cooler, plus DM flywheel adds a few Kg if you run it = around 18-20Kg, not a huge extra.
          • DJones
            • Jun 2005
            • 2020
            Bloody quick.... Ask AndyP what 490 feels like in a 1268kg car....
              It permanently altered his face
              • Bowie69
                • Nov 2013
                • 2675
                Recent pic:
                • Cottis
                  • Feb 2011
                  • 1448
                  If you are asking yourself the question and do not use the car as an everyday driver, I think you are left with little choice but to find out for real.
                  Not sure what it will be but the next fun car I have will either have to be more powerful than the last or a s8!tload lighter, preferably both.
                    This is Mr P's face now
                    • Pauliusb2
                      • Dec 2014
                      • 361
                      Lol yes simmilar
                      • Hoyle
                        • Aug 2011
                        • 44
                        • Home: Wales Current: United Kingdom
                        #26
                        Sounds like it's going to be ABY with a chip then!
                        What's the ideal exhaust size for this setup? 2.5"? 2.75"?
                        Will a standard URQ clutch hold up ok with this or should I consider an alternative?
                        Would an RS2 EM make much difference on an otherwise pretty standard ABY?
                        Would there be much point in installing a 7A exhaust cam whilst I'm at it?
                        Thanks for the replies so far chaps!
                        • Pauliusb2
                          • Dec 2014
                          • 361
                          I use genuine sachs clutch and its fine never slipped and i use 2.5" exhaust with s2 middle box and urq rear box sounds amazing
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            If you have a RS2 EM or can get one cheap then fit it
