Regarding the weight of the car, i'm curious to know what it actually weighs with a 20VT in it. My 90 quattro weighs 1210 kg. with only a couple litres of fuel in it, stock 2.2 engine but with ABS and catalyst.
RS2+ spec
I am in a similar position, running full RS2 spec and the car is very fast, probably fast enough I just keep getting the question pop into my head, "I wonder how fast 450 would be?"...Comment
Not sure about the 10v, but the ABY set-up doesn't weight much more than 7A for exampe - the only additional weight really is turbo, intercooler and oil cooler, plus DM flywheel adds a few Kg if you run it = around 18-20Kg, not a huge extra.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
If you are asking yourself the question and do not use the car as an everyday driver, I think you are left with little choice but to find out for real.
Not sure what it will be but the next fun car I have will either have to be more powerful than the last or a s8!tload lighter, preferably both.Comment
Sounds like it's going to be ABY with a chip then!
What's the ideal exhaust size for this setup? 2.5"? 2.75"?
Will a standard URQ clutch hold up ok with this or should I consider an alternative?
Would an RS2 EM make much difference on an otherwise pretty standard ABY?
Would there be much point in installing a 7A exhaust cam whilst I'm at it?
Thanks for the replies so far chaps!Comment
and i use 2.5" exhaust with s2 middle box and urq rear box
