Hi guys Iv posted before on this and I'm getting a bit frustrated with it!
I bought the car about 3years ago now and I knew it had a boosting/flat spot intermittent fault.
At first it would be OK for weeks but it has steadily got worse to the point were I am now that it will boost/Rev ok for one pull then almost go into limp mode and not really boost/pull. If I then stop and turn the car off and then on again the car will almost reset and do the same as above.
The car is a 1990 Audi ur quattro 20v rr, car has been chipped, exhaust without cats, cone air filter and forge splitter valve.
Iv had the vacume hoses changed, put a new spring in the waste gate and fitted a new n75 valve.
Iv also done a diy leak test and all looks ok, I know the hoses are 25years old and need replacing but before I spend the best part of £500 I just wanted to ask for any ideas?
Someone has suggested that the chip maybe causing the car to over boost then the ecu hold back, but this hasn't always happened?!
