max boost on my engine with a gt3582r
Another 2,2l, RC-SH750, GT3582 0.86, 8:1, 100 octane, 1,8 bar, bad camshaft timing on 7a cams, trigger error at 6500rpm (VEMS 1.1.96 - 2013), stock head. Not able to go over 1,8bar at 6000 because EGT/IAT to high in 4/5/6th gear...
is this a dyno sheet? 570hp - 800 nm ?
TWINCHARGED power,zero lag
AEM W/M injectionComment
okay,about 340 kw and 570 nm
normaly i not gonna have iat problems because i use W/M injection and this is activated from 0.5 bar until 2.0 bar boost
my goal with gt35 and stock head is 600 hp
once with my gt3076r i've had 520 hp(crank) and 635 nm on the dynoaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
i find that low numbers for a gt35?audi coupe quattro b2 2.2 20vt project (573hp-626nm)
What did you mean by bad 7a cam timing?
Sent from my LG-H955 using TapatalkComment
Bad cam timing and trigger issues are a quite senseless base for a dyno sheet imho...
Garrett shows all his permformance maps, so where is the problem? 2,4 bar as peak boost and 1,9 at peak power rpm are numbers where the turbo is running safe and producing good power. Higher numbers lower turbo efficiency and raise temperatures faster than power, so you need very good IC and headwork to still benefit from that. 2,8bar max and 2,1 at peak power is the range were you getting real dangerous turbo rpms.Comment
Both cams were advanced 4deg by adjustable sprocket. For optimal cam setup an adjustable camgear on inlet cam is also needed to adjust both cams individual.
We were not able to get rid of the trigger issues so this was the only dyno run we did.
This engine does not exist anymore - changed everything around the engine but no new dyno run. Trigger issues solved by firmware 1.2.3x last year.
this are true numbers... but my intercooler was to small2,4 bar as peak boost and 1,9[__]=oooo=[__]Comment
count this for all turbo's? in the past with my gt3076r i drive on max load with 2.0-2.2 bar boost continuously from 3800-7000 rpm!
so you suggest to drive with no more than 2.1 bar boost continuously on a gt35?
is it true that when you are on a dyno you may set the boost higher with 0.1-0.2 bar steps if you still making power with steps from 15-20 hp until it stops making more power?
this of course with an eye on the iat and max injector duty cycleaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
Im also running 2.3bar from 5000-8000count this for all turbo's? in the past with my gt3076r i drive on max load with 2.0-2.2 bar boost continuously from 3800-7000 rpm!
1360kg/600Whp Avant
0-200km/h 9secComment
