Oil pump replace or substitute for the AAN
  • prj
    • Mar 2010
    • 6308
    I recall something about making the Diesel pump work, but I can not remember the details.
    • Tom_
      • Oct 2007
      • 1301
      • Country: Czech Republic
      I want to dig this topic upwards, because now i need solve a oil pump for my stroker build aat engine block. Old pump i damaged (crack around bolts of oil pipe) So i need to buy new one. As 3B/7A (034115105B) oil cost a fortune (twice as a AAT) and AAT oil pump have the same gear ratios, is there anybody else who running AAT OIL PUMP (074115105C) ? I want to be 100% sure before i buy something. Tomorrow i get there a pics of damaged my old aat pump, if could be repaired or not.
      And why have AAT oil pump in ETKA four numbers?
      074 115 105 A
      074 115 105 B
      074 115 105 C
      074 115 105
      Thanks
      Audi Coupe Quattro 2.3 20V
        • Dec 2017
        • 5991
        Did you have any luck with this as my engine re builder has recommended a new oil pump? I don't want to pay nearly 600 euro to Audi Tradition!
          What is wrong with your OE pump?
          I have measured about 12 of these now and unless the engine has suffered a catastrophic failure they are always perfectly fine.
          I would rather use a 200k mile original pump than a brand new Febi part. Just my 2c.
            • Dec 2017
            • 5991
            Thanks for that advice because I was thinking the same. Surely if the oil pressure is ok, there is no need to change? I think my re builder is being hyper cautious. Is there any way to check the pump when the engine is out?
              Sure, measure the clearances
              • L68_hate
                • Sep 2017
                • 4
                Has anyone logged any miles with one of these Febi pumps 36342 or 32302?
                looking into possibly replacing the OE pump on my AAN
