Can MAF cause Rich running a bad idle?
  • Jonas_R
    • 3781
    • Country: Denmark
    Oki i need some kinda advice here, tried to search but get many different answers.
    It seems that when my car gets warm that would be around 94 degress (one line over 90 degress). Then it begins to hesitate and running rich when driving around 1200 rpm in 2.nd and given gas. It simple hesitates and you can fell that.
    Then if i press the clutch it start to stall and sometimes the engine even turns off.
    I have recently change both temp sensor on engine blok, lambda, clean ISV and MAF which helped a bit, but problem is back.
    Iam going to change N75 valve, Diverter valve, all hoses + got the samco kit.
    Then when this is done i gone to borrow a MAF from my friend.
    But can the MAF also cause poor idle i mean if it is making the engine run rich, then idle would be a problem?
    Also iam going to meassure the lambda probe to see if it is oki.
    Any suggestions since this is seriously driving me insane.
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • QuattroFever
    • May 2006
    • 1360
    sorry to dig up old thread. was this ever solved???
    Volcano ABY coupe
    Ant
    • Jonas_R
      • 3781
      • Country: Denmark
      Yeah my problem was solved, but I have been through a big process of tuning the car
      • A80Avant
        • 10873
        • Country: Greece
        tell the solution as well! was it the maf?
        • Jonas_R
          • 3781
          • Country: Denmark
          I cant tell you what the solution is, my best guess is that the map was running to rich causing unburnt fuel to get the car to run bad.
          • Casper...
            • Jul 2007
            • 120
            • Country: Denmark
            can it be the throttle switch/potentiometer ?
            Since it only happens when the engine temp is high
            Casper...
            • QuattroFever
              • May 2006
              • 1360
              thats exactly whats stumping me. Only when its hot it starts to play up and when sitting in traffic. if your on a long run it's fine, then if you hit a set of lights a few times in a row it starts to come back!
              Volcano ABY coupe
              Ant
