I had problem of intermittent rough idle and stall. I suspect its related to the MAF so I got a re manufactured unit recently. First impression it worked, but when I drove her out the engine suddenly refuse to rev... even if its in neutral gear (no load). No matter how low I floor the throttle it just sits still and runs pretty rough (like to stall but remains ok). Its like misfire. I pull my car off the road, wiggle the MAF connector a bit and the engine seems to work again for a while.
The act of wiggling the MAF connector suggests that it could be due to the poor contact of the MAF connector; however it cant explain why the engine refuse to rev (I would expect the engine would be able to rev even if the MAF is not connected at all)... could this be related to ignition module? or something else?
I would try to take a closer look at the MAF connector tonight...
