But how come it doesnt have any fault code from VCDS? The only code I got is:
00537 - Lambda (Oxygen Sensor) Regulation
11-10 - Control Limit Not Reached - Intermittent
Before I replaced my MAF, I did have the fault code from the MAF (Intermittent) as below:
00553 - Mass Air Flow Sensor (G70)
07-10 - Signal too Low - Intermittent
After the MAF is replaced, the code is gone (haven't done a relatively long term test though)
