engine refuse to REV - intermittent
So the throttle potentiometer does not provide the ECU with any information that the ECU uses to increase/decrease the injector duty cycle?
This was the sympton I've experienced initially. Not only the car is not responsive but also the engine is getting unstable to run, ie. stall.
I was aslo suspecting my own fault when doing the MAF connector cleaning, I took out all the pin and clean individually and put it back. I was wondering maybe I accidentally put the pins back to the connector incorrectly.... However after this I did manage to start the car finally with smooth idle but the engine is still unresponsive intermittently when the throttle is pressed/opened.RS2 >> Ferrari: Performance/look ratioComment
From your experience can the TPS itself cause the engine refuse to start at all? I am ordering the TPS now but I am trying to dig out any other potential cause which cause the engine refuse to start at all.Throttle Position Sensor would be my bet. I've had this when I've forgotten to reconnect it after doing work on the car and had a brief problem with my new build, as I was using a TPS that had sat for a while but that's cure it. It can be replaced with a spare easily enough. HTH
I am not sure if this makes sense, but if the TPS is not working correctly the ECU may think I am putting some load to the throttle while starting the car, which could inject too much fuel, flood the engine and wont start...RS2 >> Ferrari: Performance/look ratioComment
I've gone through the TPS test, and the only thing that is not agreed with the test above is when the throttle open from closed to WOT, it only increase to ~2600ohms... I thought it means my TPS is faulty BUT I found some people have same experience as well...BTDT. Scared me.
Here is some info that might help:
G69 / F60 Throttle valve position potentiometer /idle switch information:
Based on this schematic, it makes the test procedure a bit easier to understand:
Testing the F60 Closed Throttle (Idle) Switch is as follows:
Across Pins 4 and 6 on the switch:
Closed = 0 ohms (continuity)
Open throttle (slightly) = infinite ohms (open)
If either fails, adjust switch as per procedure above.
Testing the G69 Throttle Position Potentiometer:
Across Pins 1 and 2 on the switch:
Must be 1500 to 2600 ohms
Across Pins 2 and 3 on the switch:
Throttle closed = 750 to 1300 ohms
As throttle is opened from closed to WOT = increase to 3600 ohms
If NO, replace sensor.
The above test info is now available as a single sheet that you can print-off and take out to your UrS when the need arises.
I already said, the TPS does not affect anything during start.From your experience can the TPS itself cause the engine refuse to start at all? I am ordering the TPS now but I am trying to dig out any other potential cause which cause the engine refuse to start at all.
I am not sure if this makes sense, but if the TPS is not working correctly the ECU may think I am putting some load to the throttle while starting the car, which could inject too much fuel, flood the engine and wont start...Comment
Just to update, I swap the tps last night (ordered it from audi tradition) . I install in a way that when the throttle is just open I can hear the click at the same time. The vcds reveal the "TA angle" to be about 8 degree. Then the engine start! I run it for 10mins and partial open the throttle to around 2-3k rpm slowly, everything seems working fine. I'll try to get the car running on the road later tonight.RS2 >> Ferrari: Performance/look ratioComment
Just to update, I swap the tps last night (ordered it from audi tradition) . I install in a way that when the throttle is just open I can hear the click at the same time. The vcds reveal the "TA angle" to be about 8 degree. Then the engine start! I run it for 10mins and partial open the throttle to around 2-3k rpm slowly, everything seems working fine. I'll try to get the car running on the road later tonight.RS2'd 93 UrS4 5 spd sedan
That means your MAF is bad. And your TPS was bad too.
It does not use TPS info unless the MAF signal is wrong.Comment
My TPS failed couple of weeks ago and idle was perfect. Car is unresponsive when driving that's all.
