You're saying the blue and white connectors don't work? Have you checked the fuse?
Boost pressure
ECU Pin T55/13 = the "L" diagnostic connector
ECU Pin T55/55 = the "K" diagnostic connector
AAN ECU pin-out, ABY might be different colour wires (but the same ECU pins):
ABY diagram showing Pins 13 and 15 and wire colours
3B ECU diagram but the same Pins 13 and 55. Note the power from fuse S21
While this 1997 UrS6 plug looks like an OBD2 plug, it isn't actually OBD2 compliant (no C4 UrS4/S6 was OBD2 compliant). The actual pin-out is something like this:
.jpg)
Paul Nugent (S2Central.net) recently did a mini-group sale on these:
Attached FilesRS2'd 93 UrS4 5 spd sedan
So had the car up for mot 2 nite first time in about 3 years or so ,I bought it last year and did every bushin & ball joints on the flippen thing as well as a ton of other issues so it passed at least
Outside mot center decided to disconnect mfts and c wat happened and guess what I have boost, so I'm guessing I have a faulty sensor, I'm also hearing fluttering from turbo I wonder do I have a issue with diverter valve
Hopefully this is progress , need to get obd sorted as well.
Without suggestions from forum members I would have tryed disconnect the mfts thanks for help.Comment
F76 Multifunction Temperature Switch R&R Info
On the ABY/ADU, the MFTS is connected to the ECU via pin 46 of the T55 ECU connector. Using this pin as a high temp alarm (> 119 C) - the ECU cuts off active boost control as a safety measure. However, for the AAN, pin 46 is not used.
F76 MFTS info:
If the MFTS is otherwise healthy you can simply reverse the R-pin out of the connector so the ECU doesn't get the error signal. Certainly sounds like diverter valve problem if you are hearing turbo go 'koochi-coo'.
I would check continuity from ECU pins 13 & 55 to the OBD eyelets in the fusebox. If wiring is good and OBD not working, then the ECU could be running some horrible chipset. Presumably the OBD connectivity problem is only on this car and not other ones - just to rule out a laptop, cable or handheld code reader.Paul Nugent
Not a problem if you aren't in a rush. Tell me this - did I leave a boost pressure test kit of bungs with you ages ago ?Paul Nugent
Replaced mfts and diverter valve both were faulty have now boost and no fluttering
From turbo, now to sort obd port is next up, idle is still up and down especially from cold
Tryed a secondhand. Icv ,seemed better 4 a while, back to hunting up and downComment
