I guess you could try that cap from your old head and see if the shaft rotates smoothly then cross your fingers...I have seen this work but on crappy old diesel engines.
Cams won't turn - HELP!
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
Worth double checking that....
I'd remove the lifters on the inlet side to rule out a binding valve(s) or indeed the lifters themselves and try the cam shaft from your old head before resorting to swapping caps off another head.
Going through everything on the inlet side from scratch methodically will bring the issue to light.
Good luck!Last edited by K Simmonds; 29 January 2017, 06:48.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
Could it be caps 6 and 9 swapped?Comment
Double checked everything now. Will try and torque down as per Audi workshop manual.Attached Files'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
i would remove your cams and put your caps back on the head and torque them.
on this way you can see if there or any imperfections......audi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injectionComment
Just torqued everything to 10nm, and it wouldn't turn over. Loosened intake cam and did a full revolution without problems. So now I'll take intake caps off and put mine on and see.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
