Cams won't turn - HELP!
  • hunker7
    • Mar 2014
    • 3487
    Hi guys. Have a problem with my cams...they won't turn. All caps are the right way up, all in correct places and torqued to 15nm, caps,cams,head oiled and cams ain't moving.
    Checked cams and caps and there are no dents, scratches or anything, same goes for head.
    any ideas anyone?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    What have been done to the engine buddy?Need some more info
    • hunker7
      • Mar 2014
      • 3487
      Just changed heads, that's all. Cams and caps are from replacement head.
      '93 Audi UrS4 Avant
      • K Simmonds
        • Dec 2007
        • 7627
        Yep more info required, stupid question but you do have a cam belt fitted or is the head off the car?
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • hunker7
          • Mar 2014
          • 3487
          Head is on the car, torqued down. timing belt fitted and 1/2" bar at the bottom pulley and it won't turn.
          '93 Audi UrS4 Avant
          • Thuppu
            • 4115
            Caps goes with head, always, not interchangeable.
            • hunker7
              • Mar 2014
              • 3487
              Caps are from the head I bought not my original one.
              '93 Audi UrS4 Avant
              • K Simmonds
                • Dec 2007
                • 7627
                So the cams and most importantly the caps are from the head they were originally in from the factory and orientated correctly.?
                Remove the the cam belt and move the crank so the pistons are all down the bores well away from the the valves and start backing the caps off a little at a time constantly checking if the cams will move, the problem should show itself
                1994 MTM RS2.
                2000 B5 TQS.
                • hunker7
                  • Mar 2014
                  • 3487
                  How hard is it to turn engine after assembling? Not a great video but that's me trying to turn engine. Pushing on that bar a fair bit. Just afraid to shear key again.
                  '93 Audi UrS4 Avant
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    With the spark plugs removed the engine should turn smoothly with no tight spots, you should be able to do it by gripping the harmonic damper though I use a spanner on the alternator.
                    1994 MTM RS2.
                    2000 B5 TQS.
                    • hunker7
                      • Mar 2014
                      • 3487
                      '93 Audi UrS4 Avant
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        That's not right at all are sure the caps are orientated correctly?
                        You haven't by any chance dropped a small socket or bit down inside the cam belt cover?
                        1994 MTM RS2.
                        2000 B5 TQS.
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          Are you sure the cam caps are the original factory items for that head, this is absolutely vital!
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • hunker7
                            • Mar 2014
                            • 3487
                            followed Audi Workshop manual, all caps orientated correctly (looking from intake side, numbers are right way up). Caps 1 - 5 exhaust and 6 - 10 intake counting from front of the engine. Torqued front caps, and then torqued 1 3 5 2 4 on exhaust and 6 8 10 7 9 on intake. Haven't dropped anything.
                            '93 Audi UrS4 Avant
                            • hunker7
                              • Mar 2014
                              • 3487
                              They are all factory with PN's and logos on them.
                              '93 Audi UrS4 Avant
