Hello everyone
I write desperate because I found a problem when I trying to change the timing belt on my engine.
My engine is a stock ABY with stock camshafts but I have installed PKM crank gear and "26 tooth pulley" water pump PKM. The problem appears when I tried to locate the toothed belt in the stock cam gear (034109105). It don`t match. I am not able to install the belt because having the crank in correct position ( by marks in damper and flymass-wheel) the cam pulley gear need to be rotated "1 teeth" to fit it.
My question is: It is possible to solve it installing an adjustable pulley cam gear as PKM, Dahlback or Tommy´s Billet? I know this one is most used for RS2 and I don`t know if the sprocket wheel for hall sensor has the same position in ABY and ADU engine exhaust cam gear pulleys. (Is known they have different PN on ETKA, 034109105 and 105B)
What do you suggest to solve it??
Many thanks
Many thanks
