crank bearing
  • LukasR
    • Nov 2014
    • 166
    crank bearing
    As per title. I am about to buy crank main bearings for my 3B.
    getting a bit confused what to buy, as the market provides a big choice.
    Any feedback, recommendations and experience?
    Regards LukasR
    Kolbenschmidt
    • LukasR
      • Nov 2014
      • 166
      Whats the best place to buy in UK?
      Or order them from Germany? They show up on ebay but I don't really know if its the best place to buy?
      Thanks for info
      • Jonas_R
        • 3781
        • Country: Denmark
        Cs-parts.de
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • SteveH
          • 4460
          Or Glyco if you can get them at a decent price.
          91 Modded 3B
          14 A6 Avant Black Edition
          • Jonas_R
            • 3781
            • Country: Denmark
            This is the KS part no. 77209602 price is 45 euro at cs-parts.de
            • SteveH
              • 4460
              I would replace the mains thrust washers too if you're already planning on replacing the main bearings.
              91 Modded 3B
              • LukasR
                • Nov 2014
                • 166
                I think I'd go for KS for main and rod.
                And glyco thrust washers.
                Thanks for the info
                • SteveH
                  • 4460
                  Make sure you get sputter type rod bearings. They are probably all this manufacture now, but best to check.
                  91 Modded 3B
                  • steve briance
                    • Aug 2014
                    • 1455
                    I think i took Mahle bearing shells out of my engine, another alternative German Oe spec supplier.
                    I ended up putting kolbenschmidt back in as that was what the machine shop supplied but word of,warning - make sure the big end shells have the hole drilled in them. The first set that turned up were meant to be right but covered up the con rod rifle drilling....
                    • LukasR
                      • Nov 2014
                      • 166
                      I did consider mahle, glyco, KS and rs2 coated from 034 motorsport (quite expensive)
                      Anybody used coated bearings?
                        The coating is only useful for about 4 seconds if your oil supply fails
                        • LukasR
                          • Nov 2014
                          • 166
                          That's fine.
                          I think Ill stay with my choice and go for sputters KS.
                          I have noticed The 7a crank has 2 oil holes in journals and 3b has only one.
                          I am not an expert but it makes me think that if the engine gets under hard track use would 2 oil holes in crank journals make bigger opportunity to lose oil pressure in the engine?
                          Please correct me if I am wrong
