As per title. I am about to buy crank main bearings for my 3B.
getting a bit confused what to buy, as the market provides a big choice.
Any feedback, recommendations and experience?
Regards LukasR
Whats the best place to buy in UK?
Or order them from Germany? They show up on ebay but I don't really know if its the best place to buy?
Thanks for info
I think i took Mahle bearing shells out of my engine, another alternative German Oe spec supplier.
I ended up putting kolbenschmidt back in as that was what the machine shop supplied but word of,warning - make sure the big end shells have the hole drilled in them. The first set that turned up were meant to be right but covered up the con rod rifle drilling....
That's fine.
I think Ill stay with my choice and go for sputters KS.
I have noticed The 7a crank has 2 oil holes in journals and 3b has only one.
I am not an expert but it makes me think that if the engine gets under hard track use would 2 oil holes in crank journals make bigger opportunity to lose oil pressure in the engine?
Please correct me if I am wrong
