I've tried anything from my imagination and I can't figure this out. Help me!
These symptoms have been present before I bought the car. I thought a new water pump, thermostat and coolant reservoir cap would solve the problem but no. I've also bled the systems several times with no luck. Radiators have been flushed and they have no clogs.
Basically the coolant just won't flow. I have let the engine idle so that the temps rise to normal and beyond. Upper coolant hose from the top to the radiator is hot. But bottom hoses in both the main and the aux rad are cold. Blower gives just slightly warm not hot air to cabin.
I have verified that the thermostat actually opens in boiling water.
I have seriously no idea anymore what could cause the problem.
