Hello, I'm preparing to give my car an upgrade. I am currently running AET turbo 390hp 1.9 bar on Wa\gner kkk flange and would like to know if there is an upgrade available that I can fit without losing the oem look and fit. Cheers!
best power option for wagnew kkk ex manifold
KKK26/27 with a No8 hotside will yield 430-450 and looks OE. Small spacer is required on the oil inlet to clear the coldside housing and a modified maf to turbo hose. Bullet proof technology, if not a little long in the tooth. KKK26/27/29 if you're looking for more top end and lag. All the modern turbos will fit if you can get them paired up with the K26 hotside, or look for a k26 to T3/4 conversion plate and take your pick of what's out there. Turbo Dynamics make a nice hybrid, but it's not cheap
91 Modded 3B
14 A6 Avant Black EditionComment
Or you could look at rs2 billet turbo that should push over 400Comment
Is that aet turbo and rs2 unit?
If yes i Guess you could upgrade it with billet wheel.
There is a big thread on rs2 billet if you do a searchComment
From this thread
Iroz Motorsport
VRS / TTE
Turbozentrum
