S6 Plus, kickdown hesitation
  • Harvester
    • Jan 2014
    • 64
    • Country: Slovakia
    Hello,
    I have weird kind of hesitation, like a cut of in half of second. It apears only between 3,000 RPM and 4,000 RPM kickdown. For example, when push full thottle from 1-2,000 RPM evertything is okay, run smooths to the limiter. But when I hold 3000 RPM on 2rd 3rd gear and then floor it I can feel this kind of hesitation. Over 4.000 RPM I can feel this issue, under 3,000 RPM little bit.
    To this time I was solving problem with misfires on multiple cylinders. Now misfires are gone but this come out.
    Changed: All vacuum and breather hoses i can see.
    Injectors
    Crankshaft sensor, Camshaft sensor, Passanger knock sensor, driver side coil packs, two ignition modules, spark plugs, fuel filter...
    On Vag i have both O2 sensor faulty. On drivers side heating and numbers totally out and on passanger side only heating. Yesterday I have changed O2 sensor on driver side, but nothing happened.
    I am lost a little bit.
    Rather unique wreck,than a polished nothing.
    You should try asking on an 1990-94 Audi V8 forum. We're mostly turbo five manual transmission folks here.
    Good luck.
    • Harvester
      • Jan 2014
      • 64
      • Country: Slovakia
      I know, but lot of people , lot of ideas. ;-)
        I have been on this forum since 2007 and I do NOT recall anybody with an S6Plus with an autotrans on the forum. S6Plus Manuals - maybe - a very few. But autos? None??
        I have a 94 UrS4 with an ABH V8 but it is manual so no help to you. Sorry.
        Good luck.
        • fish
          • Aug 2007
          • 2333
          There were no S6 plus made with automatic transmission, only manual 6 speed with DGU code
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            just curious too.S6+ with automatic box?
            one of a few I5 from Asia.
            • veneto rs2
              • Jun 2006
              • 1022
              • Country: Veneto
              S6+ are all manual gearbox
              I think the guys refers at kickdown as per full throttle.
              http://www.audisportclub.com/
              • Jonas_R
                • 3781
                • Country: Denmark
                He does not mention it is an automatic box.
                But it does sound like an ignition problem.
                Sleeper S2 Avant +450
                A6 Avant 2.7t Stage 3
                Audi S2 Coupe RS2'ed
                • Harvester
                  • Jan 2014
                  • 64
                  • Country: Slovakia
                  I dont have automatic trans. It is manual. Yes I mean it like full throttle.
                  • Alex_GT
                    • Aug 2009
                    • 3
                    • Country: Latvia
                    Have you tried onboard measurings via vagcom? for example what happens with ingnition, maf, etc ?
                    • gms01
                      • Jun 2016
                      • 6
                      change gearbox oil filter maybe
