Hello,
I have weird kind of hesitation, like a cut of in half of second. It apears only between 3,000 RPM and 4,000 RPM kickdown. For example, when push full thottle from 1-2,000 RPM evertything is okay, run smooths to the limiter. But when I hold 3000 RPM on 2rd 3rd gear and then floor it I can feel this kind of hesitation. Over 4.000 RPM I can feel this issue, under 3,000 RPM little bit.
To this time I was solving problem with misfires on multiple cylinders. Now misfires are gone but this come out.
Changed: All vacuum and breather hoses i can see.
Injectors
Crankshaft sensor, Camshaft sensor, Passanger knock sensor, driver side coil packs, two ignition modules, spark plugs, fuel filter...
On Vag i have both O2 sensor faulty. On drivers side heating and numbers totally out and on passanger side only heating. Yesterday I have changed O2 sensor on driver side, but nothing happened.
I am lost a little bit.
Injectors
