Engine won't start 3B
  • GeorgeS2UK
    • Oct 2004
    • 225
    • Home: England
    Originally posted by porkkis
    No. I mean that originally the car would not start but you got spark and that means the dizzy was turning and hall is ok.
    Not good then, sound like I have made the issue worse,
    OK, need to replace the dissy gear (which could mean IM off)
    Need to locate and gear bits and do oil change !
    Timeing will need setting up etc....
    And possibly at the end I may still be left with the origional fault,
    Perhaps changing the Fuel Pressure Regulator at the same time would be advised
    I wonder now if my basic mech skills are sufficient.
    91 S2 3B in Pearl, Miltek, De-Cat pipes, Short Shifter, 996 Monoblocks + 323 A8 Discs, Whiteline R-ARB:MRC Generic 3B Chips
    • GeorgeS2UK
      • Oct 2004
      • 225
      • Home: England
      Fuel Pump Regulator
      If I now need to potentialy replace the Fuel Pump Regulator then would to be worth looking at an uprated one for future Mods.
      I have read that the FPR from a 7A runs at a higher pressure and will be a direct fit
      George
        It IS a direct fit, but you will run rich using the 7A FPR on stock 3B chips.
        Get a fuel pressure test done - you should see 3.5bar across the injector.
        Paul
        • audiman
          • 4827
          FPR wont make it not start. I would say replace the dizzy (complete) as you dont know if your hall sender is ok and that comes with new dizzy, along with cap and rotor arm. Complete dizzy is £148+vat exchange from the audi dealer. Maybe VAGparts can do you a deal on this?
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • GeorgeS2UK
            • Oct 2004
            • 225
            • Home: England
            #20
            Ordered up a complete new dissy from Audi as there exchange price works out quite well £132 + vat (£45 deposit against my return unit)
            Should arrive tommorow and fit Saturday.
            George
            • porkkis
              • 1994
              Paul
              3 bar in 3B when engine not running.
                #22
                I stand corrected - of course its 3bar rail pressure on the 3B - d'oh !
                  Porkis, I think if there is a sensor input missing then you just get one spark per revolution, at TDC. This is certainly the case with older systems in the urs.
                    George, when you fit the new dissy you MUST get the marks aligned exactly right, be sure to turn the engine in the right direction when checking the alignment too. If alignment is not spot on you will get a misfire.
                    • audiman
                      • 4827
                      Oh joy, inletmanifold off then, so you can get the tamper proof bolt out!!
                      Audi UR Quattro
                      • sorens2
                        • 241
                        • Country: Denmark
                        #26
                        U don´t need to remove the inlet manifold. I made a tool shaped like a "Z" out of a 13 mm wrench. Works fine. Saves U the trouble.
                        I had the same problem. Be sure to get the timing right.
                        Søren S2
                        Audi RS4 LO550
                        BTG 8:08
                        www.fredslunds.dk
                        • porkkis
                          • 1994
                          Ok, could be. I stand by Paul then
                          Søern, it might be a bit harder on RHD cars. We can access the dizzy bolt from behing the engine but on RHD cars the brake stuff might make this unpossible. And having the battery and battery support on the inlet side it probably is a PITA.
                          • sorens2
                            • 241
                            • Country: Denmark
                            #28
                            Ohh... I didn´t know about the RHD cars. Sorry.
                            Søren S2
                            Audi RS4 LO550
                            BTG 8:08
                            www.fredslunds.dk
                            • audiman
                              • 4827
                              Yeah RHD 3B is not easy to get at the dizzy!!
                              Audi UR Quattro
                              • porkkis
                                • 1994
                                Well it's not actually easy on LHD eighter and the official story is the blah blah about removing the IM but I've done it plenty of times now on different cars and no big deal with proper tools really.
