Special tool
  • jade
    • Jan 2005
    • 1811
    Special tool
    Hi all can any one please help on special tool for pully
    need to change cam belt , what does it look like , can i make one??? info please
    Regards jade
    RS 2 580HP
    Doug made one before now out of some box section i think.
    • S2 Ant
      • 3682
      Have you got ABY or 3B?
      Aircon or not?
      Ant
      2011 Kawasaki Z1000
      • porkkis
        • 1994
        3B tool
        Bought one with my friends. It's not that expensive when 5 guys share the cost. Of course self made will be a fraction of the cost.
        • S2 Ant
          • 3682
          I also have both, cheap enough to buy, however as ive posted elsewhere the ABY Tool WILL NOT FIT IF YOU HAVE AIRCON!!!
          Reason being, you have to remove the aircon mounting brackets and it should bolt in to one of these holes, which it would do fine, if it wasnt for the fact that its about the size of the pulley for the aircon too short for it to fit!
          Ant
          2011 Kawasaki Z1000
          • jade
            • Jan 2005
            • 1811
            THank for pictures
            My cars a ADU rs2 . So is it the same as the aby ???
            RS 2 580HP
            • porkkis
              • 1994
              ABY/ADU is different as the front damper is different!
              • jade
                • Jan 2005
                • 1811
                So what , do i have to send it to audi ??? just for the tooling to be correct ????
                they not very proffessional here in spain can not even tell me how long it takes !!!
                RS 2 580HP
                • audiman
                  • 4827
                  You can make your own tool using box section metal and cutting it to fit the notch in of the pulley. then weld another piece of box section onto that to lever against the engine mount at the front. its dead easy to make.
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                  • jade
                    • Jan 2005
                    • 1811
                    Cheers will look at doing it this week end
                    Jade
                    RS 2 580HP
                    • S2Roo
                      • 191
                      Hi
                      Heres one I made for my ABY with air-con. As you can see its probably slightly over engineered
                      I designed it to rest on a axel stand, after a suggestion from another forum member.
                      I will say however, I would not use leverage to undo this bolt. I think the force it too great for the woodruff key.
                      I personally would use an impact wrench (Air Gun), and gun it for as long as it takes. You will be able to undo it without locking the engine. Impact is far more effective than leverage.
                      I would however use leverage to tighten the bolt up (after it has been initially imapcted in) as the force it no longer on the woodruff key once the bolt starts to tighten. You will need to lock the engine to do this and to confirm it has been tightened to 450Nm. (Or 350Nm if you have the torque multiplier)
                      Hope this helps.
                      S2Roo
                      • jade
                        • Jan 2005
                        • 1811
                        Thanks that is a lot of help
                        Cheers Jade
                        RS 2 580HP
                        • jade
                          • Jan 2005
                          • 1811
                          So will s2 roo tool work on my rs2 , because if it will , i would like to make one ????
                          RS 2 580HP
                          • S2Roo
                            • 191
                            Yes, as far as I am aware, as the RS2 supplement refers to the AAN/ABY engine mechanical manual.
                            Roo
                            • Billman
                              • 4129
                              And where exactly does it locks?
                              Go Holset or Go RS4
