What can cause cutoff and no fault codes?
  • Jonas_R
    • 3781
    • Country: Denmark
    Oki, my cutoff is driving me crazy as hell.
    I have tried so many things. But i dont get any fault codes and when cutoff has occured i cant get over 0.9 bar boost and it cuts off around 4k if i remember correctly.
    Saw mihnea mentioning the distributer, will have to check this. But what else?
    Changed items:
    MAF
    Lambda
    ISV
    All pressure hoses to samco
    N75
    Diverter valve (recirk valve)
    Since i did this cutoff has only occured 3 times. Twice going uphill in 2nd gear and once in 2nd gear will racing from 1st-2ng gear happend around 6000 rpm.
    Well All inputs are welcome.
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • The Spanish
    • Nov 2003
    • 719
    Well you can check fuel pump also.
    Is your a 3b or ABY. If 3b check distributor if ABY check coils.
    I got cut-off because a faulty coil and another time fuel pump was going dead
    94' RS2 Coupe TT (Twin Torsen )
    • Jonas_R
      • 3781
      • Country: Denmark
      Mine is a 3B so will check distrubuter and fuel pump thx.
      /Jonas R.
      • Jonas_R
        • 3781
        • Country: Denmark
        Any speciel way to check the fuel pump and distrubuter?
        /Jonas R.
        • AAH!
          • 497
          • Home: United Kingdom Current: Bhutan
          Multi Function Temperature Switch ? Try doing a search using MFTS.
          formally RS2 +
          • porkkis
            • 1994
            Is the cutoff hard (like face to windshield type) or soft (like just loose power)?
            • Jonas_R
              • 3781
              • Country: Denmark
              Multi sensor is new
              Porkiss:
              It is face to windshield
              /Jonas R.
              • quattronutter
                • Jan 2005
                • 690
                the air temp sender on top of inlet manifold will cause probs at around 4k,you can check the resistance across it,i cant remember what it should be off hand,also check the wiring to it,ht leads and plugs may be worth checking too..
                • Jonas_R
                  • 3781
                  • Country: Denmark
                  Yeah but the 4k limit is first after the cutoff occurs. But will check it out anyways
                  Well i get a cutoff at around say perhaps 6k rpm WOT. Then afterwards i cant get over 4k rpm or 0.9 bar boost. THink the cars goes into limp home mode.
                  /Jonas R.
                  • BosnianS2
                    • Apr 2005
                    • 322
                    • Home: Bosnia and Herzegovina Current: Germany
                    I agree with the Quattronutter, i had sam problem last week. At around 4000 RPM computer was cuting boost and changing timing also, and ended up being the Air temp. sensor on top of the intake. Definately look at that.
                    • Graham
                      • 1622
                      I have had this before and it turned out to be the electrical connector which goes onto the MAF, the contacts were dirty and it was giving dodgy readings. Sprayed it with contact spray about 8 month ago and (touch wood) the car hasnt had a problem since.
                      Graham
                      • rotoryboy
                        • May 2004
                        • 3281
                        Graham
                        Apart from a glowing turbo
                        Mark
                        Race Clio RS197
                        S2 Coupe ABY (Green) - RIP
                        S2 Coupe ABY (Blue) - Sold
                        • PeterS
                          • 423
                          Jonas:
                          Had the same issue with my 3b 200, dizzy was off by a hair...(thanks to Mihnea) for help on that ( dizzy set close enough for car to start, but boost cut back between 4k-5krpm, then comes back about 5krpm!)
                          -Peter
                          Peter S
                          1990 ErsatzS2 - track toy
                          1991 Coupe Quattro
                          1991 Coupe Quattro
                          1995 S6 Sedan
                          1995 S6 Wagon
                          • Graham
                            • 1622
                            Small minor technical hitch, Who needs under floor lighting when you have a glowing turbo and exhaust, i dont think it is a KKK, its maybe a street glow
