Audiman, you are talking 500WHP right? I don't see any problem even with RS2 injectors getting 500CHP. Where does your current turbo come up to full boost now? I am a KKK turbo fan as well since both Garretts I had blew out after less than a year. I'm only running a k26#6 hot side but have the turbin clipped at 15 degrees to give it the top end of a #8 housing and full boost by 3200rpm but now with the tube header I will go to the #8 housing with same turbin and use the K29 compressor wheel with K27 machined cold side housing. This turbo has made over 600CHP on other cars but I'm only going for 500chp to keep it safe and to learn to drive the car better before spinning the tires off coming out of a turn in third gear
Elijah
.Elijah
) 500bhp eh Tom. That sounds nice. So supposing I need to get mine from a theoretical 350bhp, to say 420bhp, what do I have to change, and in what order? Is there a thread to point to what you have in yours now?
Love to know a list of things to buy though, so I can prioritise between feeding the kids and my addiction
). If you switch those factors off then you get more accurate figures. The correction factors are fine if you have a basic ecu that controls timing, boost and fuel but not much else. Our cars ECUs are already correcting for these factors.
