boot lock on coupe?
  • boot lock on coupe?
    Hi, does anyone know if the rear boot/hatch pushbutton lock is the same as the saloon models? They certainly look the same from the outside! Mine ('93 ABY) has had a peice broken off the actual mechanism & I know where there is an ordinary 80 saloon getting scrapped. Too small to glue & its made of ****** Mazak metal so wont weld!
    Thanx,
    Simon
    Simon
    Not sure about the saloon lock but you _can_ repair these things with Lumiweld, a kind of hard solder for alloy parts, you have to watch it with Mazac as you can just end up with a puddle instead of a part, but its possible, I've done several Audi door and boot locks with it.
    http://www.frost.co.uk/item_Detail.asp?productID=8823
    You'll also need one of those tiny butane pencil torches for the small stuff.
    HTH
      thanx
      Hmmmmm, thanx for the info mate, I will definately give that a go! I never heard of it B4. Sound kinda useful for fixing all those old door handles that snap off on old cars when they are getting stripped for restoration- I will tell my boss about it!
      Cheers!,
      Simon
        Simon,
        If you get no joy on the lock mechanism, drop me a mail as I can supply one from my breaking S2
        Mike
        http://www.s2-audi.co.uk
